LSA (RV-12) Flight Test - First Flight - Phase 1 - Limitations and Training
gmcjetpilot
New RV-12iS (experimental) aircraft , Builder/Owner/Pilot needs 5 hours of flight time transition training per insurance, as well as fly the Phase 1 for aircraft required by FAR's.
Can the additional crew member per AC 90-116 who is a CFI give transition training during Phase 1
I plan to get the 5 hours (or more) of transition training before first flight of my airplane. Probably at Lockwood in Sebring.
Great plan!
How can you determine if something is off during Phase 1 if you haven't actually had the experience in type?
You don't want to be learning when you're also checking your systems.
Here are some questions and my (typical) answers . Correct me if wrong:
Phase (1) flight period, two pilots (both licensed, current in catagory/class) are allowed, for intent of safety during this period ? Yes.​
(Advisory Circular (AC 90-116) assume applies to LSA)​
Phase (1) flight period for a LSA-E built exactly to plans is 5 hrs? Yes.​
(Order 8130.2J)​
Phase (1) flight period Pilot/Builder/Owner can receive and log transition training (from CFI) during this period? Yes.​
Phase (1) flight period typical geographical limitation for a LSA (RV-12) ? 55NM radius.​
(As designated by phase (1) limitations)​
Major differences between LSA-E and Experimental Amateur Built (EAB) aircraft not LSA, is the 5 hours Phase (1) IF LSA IS BUILT exactly per plans. Otherwise it will be the more typical 40 hours Phase (1). Also geographical region for EAB is 75nm radius, vs LSA-E and 55nm radius. These are typical of course, what is actually written in the Phase (1) limitations controls.
With the exception of the first, my answers would be the same as yours. It's also similar to how I kicked things off with my build last year, except that I only had to get 1 hour of dual instead of 5.
As far as the first goes, the formal requirements for two pilots during phase 1 are more complicated than current in category and class. There is a checklist and a scoring system to follow in order to be compliant with the additional pilot program. This is outlined in AC 90-116.
Normally transition training occurs before first flight for the reason already noted and also probably for your insurance to be in effect. Otherwise, you're self-insuring for those 5 hours. In addition, if you have a loan the lender probably requires insurance to be in effect before first flight so that might factor into a decision to get transition training before.
The thing about the 5 hours for E-LSA is that the flights are prescribed with flight test cards/plans. So you can;t just do transition training - you have to fly the prescribed flight plans. Good luck doing that and conducting meaningful transition training. One or the other is going to suffer.
Five hours in the life of the airplane is nothing - I did a neighbor’s RV-12 a few years ago - flew the test program in two consecutive mornings, then took the owner up for his first flight in his airplane (he had previously done transition training, but it had ben a long time before, so he didn’t feel current enough to do the first flight or flight testing). The airplane got tested, he got happy, no limits were pushed…..
Can you clarify what you mean by "have to fly the prescribed flight plans"? This seems to suggest that the test cards are regulatory. I never found anything to suggest that. The log entry per op limitations make no reference to program specifics. Is there somewhere else we should look for this?
“I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: maximum operating weight, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.”
I’m in total agreement with Paul, And will add a five hours is a minimum, but the requirement for completing phase 1 flight testing, is completing all of the test cards.
It is fairly common that depending on pilot experience, doing the phase 1 testing can’t be completed entirely in just five hours if they are putting effort in to getting accurate results.
I would ask you the same question, what is the regulatory link for an E-LSA and completing the test cards? I don't mean to be argumentative, and I'm not saying that this is to be taken lightly but this being implied as a legal requirement is interesting to me.
They're documented in the Production Acceptance Procedures (manual VAD-10007) for the RV-12. Which I believe is required to be completed as documented for the E-LSA registration.
I understand where the test cards are. I have flown them in the RV-12 that I build. Where to find them is not the question.
The PAP is not required to be completed for "E-LSA registration". That would actually be impossible.
There are clear requirements for the E-LSA during the registration process and they are well understood and related to the supply of kit materials and attesting to completion of the airplane per the KAI. Those requirements must be met for registration, which has to be done before you can get an inspection for airworthiness. The AW cert comes after registration. A flight test logically has to come after registration, inspection, and AW certification. You can't "complete the PAP" before registration.
My bad, I used the wrong term. Do the Op Lims say that Phase 1 must be accomplished per the PAP? I think that's the requirement. Otherwise it would have the 40 hour Phase one requirement.
The operating limitations do not make any reference to a PAP or anything else published by Van's.
Perhaps this is what you are looking for.
From Faa Order 8130.2J chapter 17.
  • FAA AW info.pdf
I'm familiar with the order. As with many other regulatory matters the order raises interesting questions but doesn't really seem to clarify anything. We all know that poorly written or referenced regs do happen.
Orders are written as guidance or obligations for FAA personnel, not builders/owners/pilots. While not true for every build, most of us are not FAA personnel. That document is guidance for the DAR/FAA when issuing an AW certificate.
AC 90-116 has additional pilot program matrix. Additional Pilot Program (APP) does not mean your buddy in hanger next door is qualified as additional pilot. Matrix to qualify AC 90-116 (see below). Word "additional" I assume applies to ONE additional pilot, not the one flying. assume owner/builder. The matrix has score for time, total time, time in model, hours flown last 12 months, recent t/o and ldgs... The AC says or implies either can be PIC, just decide which pilot is PIC, use CRM. All good. So only ONE has to meet matrix as I read it. If both pilots have to have time in make/model or "model series", the AC is restrictive and almost useless. It would encourage flying solo first flight with no experience vs. with additional crew who is experienced. I do think owner/pilot PIC should not only be qualified but current with recent experience, by all means, just no time in make/model. The additional pilot should have some experience in model or model series (kind of strange wording subject to interpterion). Is RV-6 time in the RV series for RV-10 or RV-12?
Let's separate can you and should you, or is it practical or prudent. If an RV-12 builder / pilot has no time it type but is very current and qualified in SEL can fly their new planes Maiden flight. Doubtful they can get insurance. They can do first flight flight solo; they can do all Phase 1, then get dual or not. It is insurance requirement to get training. Would it be better to have an experienced CFI and RV pilot fly with them from first flight? Yes. Finding an experienced instructor, willing to do flight test and training locally.
Insurance drives this 5 or 10 hours of "transition training" not FAR's. You can get dual from a CFI without permission from FAA. RV-12 is a plane and flies like an airplane. Not much unlike the physics that governs a Piper Cherokee for example, that pilot flies and owns now. However there are differences to be sure.
As far as a rigorous flight test cards, those are for Van's RV-12iS production LSA's (not experimental). However they are published and very useful. "RV-12 PRODUCTION ACCEPTANCE PROCEDURES". They are online. No luck needed. Doing these cards IS TRAINING and experience. Very basic standard logical verification of performance and flight characteristics and system functions.
True flight test and training can go in parallel practically and logically logged or not, but it depends on pilot if they can do flight test effectively at all. Should you OR can you log any dual instruction during Phase 1? I do not think their is a definitive restriction in the scenario of Phase 1 with CFI, if you meet all the applicable regulations. EAB or E-LSA has airworthiness, with Phase 1, restricting geographical area of operation and no passengers. An additional pilot is not a passenger but "Min Crew" for Phase 1.
I get your point and someone at the FAA, random inspector may agree with you. But show me where it says this? It may not be right for all pilots. What an individual FAA inspector says at your FSDO overrides, but does not mean they are right. So much that is vague or not defined gets filled in with opinion and becomes the tribal knowledge. That is why I want something in writing. I saw a definitive NO from EAA that said no training during Phase 1 because you must fly SOLO... Ahaaaa. That does not include additional pilot and change in FAR that went from SOLO to min crew. Min crew for flight test can be two... Thee AC 90-116 is not a regulation.
Pilot builder flies Phase 1 with qualified additional pilot who happens to be CFI.... If during the flight testing, the instructor observes and coaches the pilot. That is training and PIC for both pilots. AC 90-116 addresses logging PIC. It does not seem to restrict taking credit for dual given or received or PIC.
Flt test cards, example: stalls, climbs, take off and landings is required for both Phase 1 and training (initial experience, practice). Also let's call TRAINING instead INITIAL OPERATING EXPERIENCE, and is driven or required by Insurance Company, not FAA. Also a E-LSA and EAB in phase 1 still has airworthiness, except geographically limited and limited from carriage of passengers. I do not see any restriction in training. A lot has been written about flight training in E-LSA, EAB and LODA's. Not sure the answer is there?
There is no category/class RV-12 endorsement or type rating. It is a single engine land airplane. There is no official mandatory part 61 or 91 transition training syllabus or endorsement from one SEL airplane to another, certified or experimental, except high performance, complex and Tailwheel.
Show me a FAR that says a builder/owner/pilot can't log any instruction during Phase 1 from qualified CFI. I would love something definitive.
NOTE Your phase 1 FAA-issued operating limitations must note AC 90-116 is allowed during Phase I. Keep in mind AC's are not regulatory unless they are related to a controlling FAR. It is far to say (I think) if the Phase 1 LIMITATIONS states AC 90-116, additional pilot program is allowed during Phase 1, than the AC is regulatory.
My interpretation is close enough to your regarding APP. Both do not need to meet the score in the matrix for 'additional pilot', one does.
To get back to the original question, every situation is a little different but I'll offer mine as one example. I tried very hard to get transition training in an already flying RV-12is with a CFI. This time last year, that was nearly impossible to do. Seager had already told me he was too busy and I needed to go somewhere else and referenced the Van's site. Van's site was outdated info. There are/were very few RV-12s available to train in, and of the ones that were many were down for one maintenance issue or another. Mostly landing gear repair related if I recall correctly. I went all the way from California to Wisconsin in June with plans to fly there but got skunked by the wildfire smoke. Per my insurance, I need 1 single hour of dual but of course I was willing to do more to feel good about it.
My insurance eventually agreed to cover a local high-time part-time CFI with extensive experience with flight testing including other model RVs. He was named insured and covered on the first flight. They stipulated that he needed to get 1 hour in the airplane before giving me the 1 hour that I needed.
He flew the first flight. It was a little over an hour verifying the basic control characteristics including stalls, flap configurations, observing temps, etc. Of course with it being a -12 built by the book there wasn't really any surprises. His requirement to instruct me per insurance was met. We then flew the next hour together doing almost the exact same flight. It was enough to establish that the airplane flew as expected and for me to be comfortable and safe doing takeoffs and landings. From there I completed the test card flights and phase 1 as prudent and required. This worked well, and for this particular airplane it's hard for me to think we did anything unsafe or foolish.
First off let me say that I admit there are some disconnects when we talk about regulatory details regarding LSA.
The ASTM committee has been working to close those gaps, but for some of it, it has been taking a while.
But technically the biggest issue in this regard is with Experimental amateur built.
E-AB and E-LSA receive the exact same operating limitation "I certify that the prescribed flight test has been completed......
For E-AB, what is the prescribed flight test? It is not testing within the stipulated flight test area for 40 hours. That is the required minimum flight test duration.
But since there was no prescribed flight test, the 40 hrs has been the lowest common denominator reference that has been used.
That has now been at least partially correct with the FAA introducing the task based flight testing program (though they left in place the option of using the old reference of 40 hrs) :unsure::cautious:.
With LSA, the disconnect is that a lot of the regulatory basis is within the Consensus Standard (ASTM's). There are actually only a small number of FAR's that directly regulate LSA. The rest is handled within the ASTM's, which the FAA does require compliance with, by use of the FAR's.
I can't point you the specifics in the ASTM's regarding this discussion, because the are a subscription based document that I no longer have access to since I am no longer employed at Vans.
So where the big disconnect comes from is that Van's is required to meet all ASTM requirements. Producing the PAP document and providing it to E-LSA builders was just one of hundreds.
Van's is required to follow and use a very similar document for every SLSA they produce, and stipulate that an ELSA builder do the same (Though the PAP is a bit different in order to make it easier for a novice airplane inspector and test pilot to follow).
The way this can happen is that the ASTM's mandate (and empower) the manufacturer to regulated certain aspects of the building, operating, inspecting, and maintaining of aircraft it has produced.
Having said all that, the disconnect is that there is nothing in the FAR's (that I can think of at the moment) to regulate an E-LSA builder to follow the PAP other than that the aircraft to be approved as an E-LSA, it must meet all pertinent parts of the consensus standard (which ELSA builders don't have access to).
In simplest terms, if an E-LSA builder wants to do that, they must follow all of the directives of the ELSA kit manufacturer.
Example - To be certified as an E-LSA the aircraft must be built exactly as directed by the manufacturer. This isn't in the FAR's but it is in the ASTM's and Order 8130.2.
Regardless of whether any regulation encourages or prohibits accomplishing the 5 hour insurance flight training concurrently with doing the 5 hour E-LSA fly-off it is just a bad idea. Is someone really getting the transition training they need when they are busy setting up AOA parameters and autopilot settings, feeling for a heavy wing, etc.? These wonderful examples of an airplane burn 4 gallons an hour of mogas so flying an "extra" 5 hours is what......less than $100 of fuel wherever you may be located. A phrase I hear often is "we fly experimental, we can do whatever we want." So it may be less than optimal to cover both requirements in the same flight but "we fly experimental, do whater you want."
Regardless of whether any regulation encourages or prohibits accomplishing the 5 hour insurance flight training concurrently with doing the 5 hour E-LSA fly-off it is just a bad idea. Is someone really getting the transition training they need when they are busy setting up AOA parameters and autopilot settings, feeling for a heavy wing, etc.? These wonderful examples of an airplane burn 4 gallons an hour of mogas so flying an "extra" 5 hours is what......less than $100 of fuel wherever you may be located......
I appreciate all you said. Let me assure you. The experienced and current pilot is getting inital operating experience and doing Phase 1. The pilot is flying well after 1.4 hr, 2 flights, 2 landings, slow flight, stall and recovery. Flight check items are being checked off just by flying.
As far as AOA cal, with the APP (additional pilot program), it will be safer than doing it solo. He will finish 5 hrs with me and fly solo 5 hrs before flying a PAX. During that 5 hr solo he is free to gain experience and do more testing and calibrations. This 5 and 5 was a limitation that was imposed, but not by me.
As EAA Tech Conselor before I flew with pilot we spent two hours. I picked up a handful of minor issues that were addressed. Gave 1 hr of logged ground instruction going over the plane, preflight, limitations and paperwork before first flight.
1st flight was by plan short, 0.6hrs. If there was any issue we would have landed immediately. I was able to record data, verification engine and aircraft performance, checked off a lot of items (after flight). Yes I was busy monitoring and recording. Plane performance was exactly the values Vans Aircraft. Flight resulted in 3 minor write ups. I was able to share workload with pilot, CRM, to allow pilot to focus on flying, while I did radio and looked for traffic. Like we do in airlines. This is all good. I gave pilot some tips, called out altitude, heading, airspeed and suggest pitch and power (i.e., instruction). Very organized, routine.
The 1st flight pick-ups were corrected (cowl to exhaust clearance, flaperon to SOB clearance very nicely. Slight, minor left heavy wing (very slight) is not being corrected until flown more, per Van's instructions. Other than that the airplane is well sorted out in prep for flight 2, and the pilot is getting use to plane nicely. NOTE you mention heavy wing as a reason not be get instruction during Phase 1 makes no sense to me. Again they are a full fledged pilot. They are not learning to fly. This "instruction" is not for a rating. If the wing is too heavy we knock it off and land. That was not thee case.
2nd flight 0.8 hours shortened a bit due to weather (isolated CB's) approaching. Autopilot use, stall and stall recovery, 2 landings. Pilot did radio and I gave less tips. It was windy with 8kt cross wind. Taxi with free castering nose wheel is new to him. He is getting the hang of it nicely, but we are focused on this in all phases, taxi, t/o and landing, especially in cross winds. Cross winds is my pet topic and pet peeve. Many pilots are not proficient, and may have never learned proper cross wind takeoff and landing. I am a stickier on this topic.
Continuing with longer flights. I anticipate pilot and plane completing goals, pilot proficient / comfortable, checks and as required adjustments done. However you are never really done adjusting and testing. If we need more time we will take it. No rush. It's going well. This RV-12iS LSA is a good well proven design, built to uniform standards, has been surprise free.
RV-12 has an excellent accident history, and phase 1 and early flights mostly go safely. However there are many that happen in first 8 to 10 hours of aircraft operations, even 1st flight. Even though total fatal accident stats are above average for RV-12, early accidents represents a significant percentage of RV-12 accidents. Always be focused. We are not complacent. Getting training and APP with an experienced safety minded pilot adds safety margins, makes Phase 1 more efficient. This will reduce all accidents especially early accidents. Doing Phase 1 in itself is good training, but getting another set of experienced eyes to observe, guide, critique and instruct is better than trial and error. Thank you everyone for your replies.
PS Also use EAA Tech Counselor Program. An experienced builder, will inspect your work and may have pearls of wisdom and suggestions.
Here's the problem I see with this explanation in the context of the PAP and questions raised in this thread. It's not true that Van's even stipulates that an ELSA builder follows the PAP. For whatever reason, they excepted that out of the documents in the one place where there could have been a connection made. I can't help but think that was intentional, and not an accident.
To register my RV-12is I had to submit an 8130-15 along with the other paperwork, and had to attest with signature that I followed those guidelines. The 8130-15 is a document that is completed and provided by Van's and has Rian's wet signature. That document lists the ASTM standards and mfr documentation that is in support of all of the requirements for the E-LSA compliance.
The box on the form provided to me show's "N/A" where the PAP would have been mentioned. The PAP is not among the directives stipulated by the manufacturer in the case of the RV-12is.
This Form 8130-15 was not filled out correctly.
I have just communicated with Rian and he is going to look into it and make sure it doesn’t happen in the future.
Well training and Phase 1 is complete.
Training the big differences for the pilot that took practice in no particular order:
Free Castering Nose Wheel
G3X use, scan interpretation.
Aircraft 1000lbs lighter
Stick and Responsiveness of Flt Contl's
Rotax (burping) power setting
Trim use, ABIT always be in trim and check list displine
Sight Picture on Final "aim point"
Flaring too high
Airspeed limits
Inadvertent hitting Freq Flip (button on control stick with 3 other buttons of identical size, shape and feel)
Knee (thigh) board no good, interferes with stick, throttle
Emphases on winds (cross wind) when taxi, t/o and landing) and we had lot's of opportunity to practice (winds varied, 30 to 90 degree, 10-12 gusting 20 many flights).*
Phase 1 item squawks all corrected
G3X ADS-B out (Set)
G3X Stall Warning Tab Aural (Set)
G3X trim motor direction & A/P (Set)
G3X AOA calibrated (Done)
Right flaparon rub fuselage when up (Fixed)
Exhaust too close to cowl (Fixed, loosened exhaust and retightened)
Left Wing slight low (adjusted link, hands off level)
Rudder & Elevator Cable play check (My request, access gained checked, all good)
The check list he was using did not have flaps or flaps in right section of checklist, hand wrote it in.
*NOTE LSA is subject to wind more than heavy plane, BUT the RV-12iS has very responsive and capiable flight controls which midigate the light weight. However it requires the pilot to make proper and timely control inputs. Along with the free castering nose wheel it makes the RV-12iS almost like a tail dragger, in the sense the only way to keep directional control on the ground is with rudder, aileron and elevator (and brakes as needed). Nose steering does make it easier. T/O Weathervane and P-factor takes timely input of rudder and sometimes full deflection and application of down wind brake. Free castering vs nose steering us significant difference. We flew with wind every time, with cross wind, except the last flight together, it was calm. A peice of cake for student at that point.
I find students I have for transition, aircraft checkouts, flight reviews, high performance, complex or tailwheel endorsements do NOT have a sold grasp on cross wind takeoffs and landings. Second they don't know what an aim point is and/or how to use it effectively. Yes there are VASI and PAPI on some runways, but aim point is key to making a good stabilized approach on speed. The "stabilized approach" is a prerequisite and how you make good consistent and safe landings. I find 1/2 of aircraft checkouts or transition training is reviewing basics. I say if you can fly a C-152 like a boss, all required tasks, well within your pilot certificates standard, current, competent you can transition to a new plane fairly easily. Transitions weed out weak areas.
Some Builders don't fly at all and jump in the new creation. Having another set of experienced current eyes is key. Accidents on first flights has gone down but not zero. There was an accident in Florida this week with a LSA first flight by pilot builder. If not first flight it may have been second flt. The model MERLIN LITE. https://www.aeromarine-lsa.com/merlin-lite/
Please be careful. Finding a qualified additional pilot for Phase 1 or flight instructor for transition training, in your area to fly with you can be a challenge, I read and hear over and over. I would not recommend a local CFI with only time in CESSNA or PIPER giving training in an EAB or LSA they never flew. However if the CFI has other similar EAB or LSA experience it may be OK, but less than ideal. Ideal is recent experience in same make and model or at least same series.
this thread brings up a subject that I have very strong views on. I see a very dangerous trend starting in the EAB world. As kits have gotten more and more advanced and more and more planes flying, phase 1 testing has gone out the window. people are taking phase 1 to lightly. I see way to many people just going out and flying around for the prescribed amount of time and not having a test procedure in place. the numbers a manufacturer gives for their product may or may not be what your aircraft will have. I take first flights very seriously. I was against the ACM program for that reason, I predicted that people would not follow the checklist and just use it as a excuse to take someone with you on the first flight. as some have said, a first flight should be a short flight to determine basic flight characteristics, critical system performance, a safe indicated approach speed, and control response. there needs to be a plan for all possible issues. its a tough call to make after spending a lot of time building your creation, but if your not qualified current and mentally up to the task of a first flight, either get the training and experience to do the flight or get someone that is to do it. most first flights go fine, but if not it could be a matter of life and death. take it very seriously people and do it right.
AMEN! And this is not a new trend. It has been growing for years. These new "exception" rules make it much easier to make "Parker P-51" sign-offs.
If you know what a "Parker P-51" logbook entry is, you're showing your age.
Unfortunately we are in the minority. Most people think the new rules are great. Phase I flight testing is for "Testing the airplane", nothing else. It is NOT for flight training, transition training, joy riding, or anything else.
FLAME SUIT ON!
FLAME SUIT ON!
thats part of my first fight procedure, nomex flight suit , gloves and leather shoes.
I have not read everything in this thread, but after reading much of it, I thought it might be useful to see what's actually in the test cards. A google search for "RV-12is test cards" found the following page:
RV-12 Production Acceptance Procedure
I'm still very far from completing my RV-12; I found it enlightening to read. Each flight test, as well as the ground and taxi tests, is signed by the person who performed the test, indicating that it was properly preformed and that conforming results were obtained. It includes a long section that describes appropriate test conditions and test pilots. The way I read it, if those tests are not fully and properly preformed as indicated, you have a problem. Van's won't accept that you've actually built an RV-12 as they desgined it. If they don't accept that you've followed their acceptance procedure, you may not actually have an RV-12; perhaps it's an EAB airplane. I'm personally very glad that this acceptance protocol is there for me to follow.
Flaring too high
Airspeed limits
G3X ADS-B out (Set)
Way too much speculation from the uninformed for a fatal accident. This is a single pilot airframe.
"single pilot airframe" ???? Yes I know this is a SINGLE SEAT ultra light/LSA. I never said there was some direct analogy to RV-12iS. That was not the point. What was his currency? What was his pervious experience. Was his plane gone through by EAA Technical Counselor. FAA or Designee is not a airworthiness' inspection. Did he reach out to other owners of this Ultralight/LSA or get them to look it over? My point is there are too many 1st flight accidents and how can we reduce them. It is far better in 2024 than in 1985. The BD-5 accident rate was abysmal. Again single seat.
You wrote "uninformed from a fatal accident"? What do you mean? I am sure you missed my point. I am not going to guess, so please be so kind explain. BTW the TV report was surprisingly accurate and well done for local TV news. The Police spokes man was very knowledgeable of the individual.
What "speculation"? I don't see any speculation and TV report was surprisingly fact filled at least for local TV news standards. We know he crashed and died, sadly and tragically, RIP. Why we don't know. Witness say he stalled (from my interpretation from TV report).
Yes single seat planes present an issue with transition training, unless there is a two seat plane that is similar. If some one is new RV-3 pilot RV-4 would be a great trainline. Single seat ultralights, LSA and EAB's are a challenge.
BTW RV-12iS has two full controls, stick, rudder, throttle, flaps, trim, brakes.
Getting someone who can help in a particular plane, even RV-12iS or RV-7 or MERLIN LITE is still a challenge for many builder pilots to find, even if the plane has two seats with dual controls. This is why the Additional Pilot Program per AC 90-116 is a great thing.
Let me repeat, first flight accidents are much better than in the 80's and 90's, but still too many and avoidable. I remember dozens and dozens over 40 yrs as if they happened yesterday. Most if not all could have been avoided. That is why I do transition training for new builders and project inspections. My last one (this RV-12iS) was very satisfying an productive. I am sure the training he received will make him safer. The build squawks I found was value added. Could SOMEONE have helped this Gentleman in South Lakeland? May be and he would still be with us? I don't know but possibly.
I believe he was referring to the Florida accident that you mentioned. It was a Merlin Lite which is a single seat ultralight.
Yes I know. Thank you. I revised my post just as you were posting. I know it is single seat. Single seat ultralights, LSA, EAB are a challenge to get training in. This is not my point. My point is how to reduce EAB accidents. AC 90-116 has some background data, abysmal accident statistics in EAB;s in the first 8 hrs. Obviously additional pilot is not always possible, but how about getting EAA Tech Counselor to look it over. Try and reach out to current pilots in make and model; talk to them or get them to look your plane over. Why did he stall (apparently)? I HATE IT WHEN PEOPLE DIE IN PLANES.... It is tragic and often can be avoided. We need to do better in making training available. This has always been an issue with ultralights and any single seat planes (BD-5, RV-3). In the case of a RV-3 you can get dual in an RV-4.
FLAME SUIT ON!
Where does it say that. There was no joy riding. The pilot flew phase one. I observed and gave them some training. Not ALL flying was training. Are you a CFI? I have b een for 34 yrs. I can give training to anyone I want without your permission. There was no LODA needed.
It is my mission and PET PEEVE... There was no doubt the level of safety with my last student, phase 1 and transition training was high. Obviously I am current and high time and could (and would) take over. But to your point there was a lot going for a pilot with fairly low time transitioning into RV-12iS. As I mentioned nose wheel steering to free caster nose wheel, the G3X, autopilot was interesting. He was clearly learning. These sophisticated EFIS and autopilots requires a learning curve. Being able to absorb all the data on the glass was obvious, not to mention the button pushing (or icon pushing) to get it to do what he wanted.
I saw this as a new airline pilot and my time working for Boeing teaching pilots in the simulator transitioning from steam to glass in the early 90's. Now that glass is ubiquitous you think everyone has a grasp. Well when a pilot goes from Boeing, Airbus.... they get months of training on the airplane. MY issue is in GA, a G3X is not a Dynon Skyview is not a GRT Horizon 10.1 or a G1000 or or Garmin GTN750 or GNS430W,,, There is much button pushing, knobs, menus it takes effort to learn. Even if you can watch videos and use desktop simulators (very limited), it is time in plane that is critical with good IOE (initial operating experience) with a check airman (or CFI in GA). I have a hard time keeping up with all of the GA glass, staying current or proficient. Many are touch icon screen controlled, but still "technologically advanced" aircraft is a challenge for CFI's and pilots alike. My G3X chops could be better.
PS we did very short flights and added on slowly. That has been by CFI style from the early days. Students max out early on after an hour. The max flight we did was 0.6 to 0.8 hrs. At the end we did 1.2 hr flights. This is "Transition Training", of a current private pilot. As I said above the unique characteristics of the RV-12iS vs, PA28-180 (which has a GNs520W), with G5 was enough to bite off. In the end he was competent. As you implied being overwhelmed with the new may cause them to miss the basics.
I've flown as the Additional Pilot for many first flights in RV's, and I would encourage ANY builder to enjoy flying the FIRST flight in the airplane he spent so much time building.
BUT.... Just ask yourself first WHO would be logging PILOT IN COMMAND on the flight. It needs to be the builder/pilot, not the additional pilot. A first-flight is no time to learn how to fly the airplane. Get your transition training FIRST in the same model RV. THEN find a qualified additional pilot to fly with you to enhance safety. What I've seen go wrong: Total failure of the EFIS (no altitude, airspeed), flight controls locking up, autopilot/trim unexpected inputs, engine failure on final resulted in a dead stick landing. This is not the time to think about "transition training" and learning to fly your airplane. Be smart. Get that training before flying yours for the first time.
I've flown as the Additional Pilot in many first flights in RV's, and I would encourage ANY builder to enjoy flying the FIRST flight in the airplane he spent so much time building.
I appreciate what you are saying, but confused.
first you say " would encourage ANY builder to enjoy flying the FIRST flight in the airplane he spent so much time building. :"​
Then "Just ask yourself first WHO would be logging PILOT IN COMMAND on the flight"​
Then "A first-flight is no time to learn how to fly the airplane"​
Transition Training or initial experience is not LEARNING TO FLY. When you take a flight review is that "learning to fly".
Ideal is go find a plane and CFI to give you transition training. OK. Now with X hours (dual only), you go fly your RV-X & RV-XX the first time SOLO and engine quits 100 ft in the air (BTW I simulated this). Would that be better? I hope your CFI transition instructor prepared you. Or would it be as good or better to have a high time (make. model. total, recent time and recent landings) on your first Phase 1 flight who has built an flown phase 1 in EAB's..... THINK ABOUT IT.
PHASE I flight test is "no time to learn"? Why? Oh all hell could break loose, heavy wing, fire, wing falls off, engine stops and pilot "learning". How is that made worse with an experienced pilot next to you? BTW my "student" got power off landings, simulated loss of thrust in pattern, initial climb, en-route. BTW flight maneuvers is part of Phase 1, Vs0, Vs1, Vx, Vy, Vne, best glide. Phase 1 and initial experience (training) go well together.
Second first flight of an RV-12iS is not like 1st flight of 1960's NASA X-15 or the SR-71. There are about 800 RV-12's flying. Kind of a known quantity E-LSA, with a stall speed of 41 kts (47 mph), 100 hp, single throttle lever, no mixture, no propeller. Also the pilot flying (builder) is a private pilot, with pilot skills an can do that pilot stuff. He is not learning how to fly he is getting initial experience an training. If it was not safe and legal I would not do it. Keep in mind not all of a flight has to be training. The logged training is for insurance.
For the love of Regs you all PLEASE read who and when a pilot can log PIC. You all act like Additional Pilot is not for "safety" but a time building scheme.
YES before takeoff decide who is PIC. If there is control transfer you say I have the plane, other pilot responds you have the airplane. I can tell you I will be on the controls like white on rice in a fraction of second and take the plane if the planes vector exceeds safe parameters. CFI's know how to monitor and correct if needed.
For the love of Advisory Circulars YOU ALL please read
https//www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentid/1025667
This is no time building scheme or joy riding. This is for SAFETY. Additional Pilot requirements are spelled out and not trivial.
Phase 1 is to determine the plane operates normally throughout the operating envelope, systems, engine parameters and controls are normal. So as the pilot flying (builder) gets some tips from the Additional Pilot, RPM, pitch, airspeed, configuration) who is also a CFI, this is training (not learning how to fly). If it was too much or not safe I would not do it.
This guy was lucky to find an experienced CFI (+1200 hrs in RV's) willing to fly as additional pilot during Phase 1, The the real road block is availability of RV pilots who are instructors, local and current. However I am available in Hawaii if you pay all expanses. 😀
IT IS DONE... No need to opine how unsafe it is. It worked out well, safe, legal, productive and fun. This just may not be possible due to availability of qualified CFI that will fly out of your airport (your Phase 1 is limit to).
Sorry but this thread is over.
